Peavey Delta Blues Distorted
  • Peavey Delta Blues Distorted
    I have 2 Peavey amps ... a Classic 30 and a Delta Blues 2x10. According to Peavey, they are identical but for speakers, tremolo on one and physical size. Both are Made in USA, both are 2014.
    I just got my Delta Blues last week from a Guitar Center a 1000 miles away. It was advertised as in mint condition.
    Cosmetically - yes - performance wise, she sucks badly! The reason I bought it was because I tried one in a store down here and it blew me away. I had to have one because of the 10" speakers.
    Well, I got it fairly cheap so while I waited, I ordered new stock tubes and a pair of Celestion Gold 10" . Sure enough, when it came and I plugged her in, there was a very light, tone robbing distortion right from the #1 position of the dial and up. When turning up, it did not intensify, it remained light and fuzzy.
    Well, piss me off! In go the new pre and power tubes with my happy ass whistling Dixie and other great southern hits, only to have the EXACT same condition.
    So, with the speakers and all tubes changed out where do I go next in my trouble shooting?
    I have great soldering and assembly skills BUT I am no way a technician. Just desperately trying to save cash that I don't have.
    BTW, the Classic 30 is flawless!
    It's possible one of your new expensive Celestion Golds is defective. How disappointing, but sometimes NEW does not guarantee GOOD. Try your DB thru a known good working speaker. If that "very light, tone robbing distortion right from the #1 position of the dial and up" continues then we have to look at the amp. It might be simple as under biased output tubes, or an open screen grid resistor, or bad as a defective output transformer.
      OG mentioned that the problem existed BEFORE the speaker change. That doesn't negate your observation at all, but it does change the focus. For me anyway.
      Fully agree about seeing to it and then going into the circuit though. I also concur with the initial considerations about potential circuit faults.
        Have you ever taken either of these amps apart? The circuit boards are folded up three sided with jumpers connecting the three boards and are a PITA to work on. These jumpers tend to loosen up when unfolding them and can create additional problems. I would suggest getting a hold of G.C. and inform them of the problem. They should provide you with a working amp! You can save the Celestion Golds for a speaker update on a different working amp.
        Turn it up so that everything is louder than everything else.
          This is a used amp. I'm sure GC will try to help, but in a limited liability way Pretty sure they won't feel obligated to find OG another 2014 Delta Blues and ship it to him.
            Bingo ... besides, deal was too good to be true - it was their description that was a bit BSitty
              New golds go into my Super first. Nothing that this Homey buys gets installed before testing... too old to screw around. All 7 tubes went into my 'known' working Classic 30 - BOTH DB ones and the new set I purchased for the DB. Now, back to discussion ...
                Not yet although since both amps are identical but for a tremolo circuit and speakers, I thought I could use the Classic 30 only as a visual guide in case some junior rockstar tried to mod something improperly.
                Boy, this is turning out to be some upcoming week ... working on my bread & butter Super Reverb as well as this DB.
                  I would hope that an amp arriving basically non-working would merit some form of compensation at least monetarily so you can look for a different one. It's not like you got it off Craigslist with all sales final. Anyway, here's what you're up against in case you haven't looked for a gut shot.
Name:	Delta Blues.jpg
                    Then the game is on - problem must be inside the amp and as noted it is a pia to work on. I'm impressed with your thoroughness in testing your new parts before installation. Everything's calm as could be here , as long as I avoid paying attention to the news .
                    You can check OT primary windings continuity with an ohm meter, same for screen grid resistors. If both tests reveal no problem, it sure would be good to pass a sine wave thru the amp & watch output on a scope, that would show insufficient bias current as a crossover notch on the amp's output, or might indicate something else unexpected like a distortion induced by drive stage, or possibly ultrasonic oscillation.
                      Don't these have an FX loop? How does it sound if you plug into the FX return (or pwr amp in)?
                      Does the Classic 30 have a loop? Run pre-out (send) of one amp into pwr amp in of the other amp, and vice versa. At least then you can narrow down to pre or pwr amp (or power supply if both pre and pwr sound bad).
                        [ATTACH=CONFIG]42230[/ATTACH]
                        yuk
                        slot siteleri
