Ok, I'm sure I'm going to get stick for this but here goes.
I decided to do the famous EQ mod on my Champ 600. Pulled the chassis, soldered my wires and pots as per my mod diagram then removed the four relevant resistors and soldered in my pot. Switched it back on and ......nada, no EQ. Given that I've never worked on a PCB before, I think I made a mistake going in 'on top' instead of underneath. Realising this, I pulled all the jumpers and flipped the PCB. The holes were burn out.
I managed to put three wires back in but they don't seem to be 'taking' to the PCB cleanly though I have continuity between them and certain other points on the PCB that I'd expect to find it. I have some conductive paint on the way but is there anything else I need to get to surround those burned out holes to accept the solder?
