Almost picked up one of these cosmetically-great little amps for $40 at a flea market. Connected a stereo speaker they had lying around, just to see if it powered up, and if it made noise. Took a cable to plug phone in to play music, to see if it made sound.
I warned the shopkeeps that ANYTHING could happen with this thing, since nobody knows if it works, if tubes are bad, or if anyone tried to "see if it worked without a speaker connected". I told them that ANYTHING with tubes needs a speaker connected before powering up, or the thing could self-destruct. "Oh...we didn't know that. I think somebody DID look at it a few weeks ago." They were to have me plug into a power strip that had a couple things plugged into it. I asked if there was anything important plugged in, because there's a possibility of tripping the breaker. "Just a couple signs", they said.
The thing had no power light (on the original unit), so one could only just look in back to see if the tubes started to come up (which is what I would do anyway) to see if it had anything.
With nothing plugged into input, yet, and with speaker connected, turned it on. "Oh, good. Didn't trip the power strip, and the tubes are starting to glow!"
Then, "OH SHIT!" The rectifier tube had sudden pulsed flashes, before I could get the switch turned off.
"Hmmm...THAT ain't good!", I told the shopkeeps. I thought, "Well...maybe it just had some bad pin connections?" (but was pretty sure that wasn't it).
So, I reseated all the tubes, checking the pins. They didn't look too bad.
Turned it back on, and zilch. Nada. Nothing. Still, didn't trip the power strip.
"It doesn't work", I told the shopkeeps. "I suspect it may have been plugged in before, without a load, and did just what I told you it would probably do if a load isn't attached".
If I had just chanced it at a garage sale for less than $40, and brought it home untested, I sure would have checked things out first, and brought it up in a more careful manner. But, I had no tools, and wasn't gonna carry stuff in there with me, and I doubt they'd have let me disassemble the thing on the counter, anyway. So, only thing I COULD do is make sure it had a speaker connected, and roll the dice.
They gave me a slip of paper to write a note on it, explaining to the booth renter what happened. Told him I properly connected a speaker, turned it on, and it fried. Left my phone number, asked what he wanted for it, now, since we know it is faulty. Not gonna give him full price!
Anyway, if he calls, wonder if it's even worth $20-$25, not knowing for sure if the transformer is blown, or if it's something less troubling?
Linked is the exact same unit (except this guy modified his). There's also a couple more videos on YouTube with this model. Seems like a snarling little critter, from those videos.
https://reverb.com/item/917613-bouti...ss-a-blues-amp
Thanks,
Brad1
Thanks,
Brad1
