SF Deluxe Rev:cathode bias switch help?
  • SF Deluxe Rev:cathode bias switch help?
    Hi,
    I want to change my SF Deluxe Reveb to switchable cathode bias as in
    http://www.londonpower.com/cath-fix.htm.
    Has anyone tried this mod, is it reliable, how does it sound?
    Any help, hints, wiring diagrams much appreciated
    Zouto
    I did this in my 4 x 12AU7 output stage amp. I like it quite a lot. I actually went one step further and made it so I could run one tube on fixed bias and one on cathode bias (as well as full cathode or full fixed).
    I find myself using it on the inbetween position most of the time because it gives me a best-of-both-worlds sound and feel. To do that I needed to use seperate cathode resistors / caps for each tube pair (something I would have done anyway) and used a 3 position rotary switch (doubling up contacts for additional current carrying capability).
    It is reliable in my amp, however mine is only about 14 Watts. Will you like the sound? I don't know. I like the way it sounds when I am trying to get a vintage sound but I prefer the fixed bias when I have the hi gain channel selected. The cathode bias can get a littel mushy and indistinct with high gain.
    Sorry, not diagrams here. Kevin's drawing is pretty good, I owuld use that.
    Good luck,
    Chris
