Hello All,
Got me a drip edge Silverface Baseman AB165 at a great price. Went ahead and modified the output to AA864 spec. Put 0.047uF on the output instead of the 0.1uF. Made it a fix (adjustable) bias. 47k output plate resistor as per AA864. 820ohm and 100ohm on the negative feedback (AA864). 500pF coupling cap just before the PI. As for the Bass Channel I just basically modified the tone stack to .022uF/.022uF/56k/330pF and left everything else as is.
I was curious as to what others had done with this channel to make it more useful. I see an unused triode sitting empty that has me tempted to add a gain stage to the first channel. Has anyone used the extra gain stage here? The deep switch is waiting to be modified as is the ground switch ing the back. Also, has anyone switched out the 250k bass pot for a 1meg pot in channel 1?? Attached is a gut shot of what I have so far. Thanks
