Hi everybody,
I have been reading on this forum for years and learned a lot. A lot of knowledge is available here. Thank you all for that.
So now it’s time for a question:
I recently acquired an older Peavey Delta Blues amp (1999-2000) . It has footswitchable channels and tremolo but the boost function can only be activated with the button on the amp.
I would like to be able to operate the boost with a footswitch but the only mod I have found is on the Blue Guitar site and is rather complex, adding a relay (which needs power).
I am looking for an easier way to create a foot switchable boost function. With easier I mean the switch should only make/brake a ground connection. That way it will be easy to build and also be save.
I think I found the solution in my VHT Special 6. It has a volume boost switch that is implemented rather simple. The (fixed) tone stack is grounded with 68K resistor and the footswitch just bypasses this resistor. Since both tonestacks are Fenderish I think a similar set up should also work with the Delta Blues. Just lift the grounded leg of the mid pot and connect it to ground with a 68K resistor on an extra jack at the back of the amp. The footswich wil then bypass this resistor. The effect will be different from the factory boost which is a midboost, but that’s not an issue for me.
Also without the footswitch connected it will not be switchable but I could even use a 60 K audio pot with a push/pull switch on the back of the amp (instead of a resistor) to make the boost adjustable and also switchable.
Do you guys think this will work?
Delta Blues schematic: http://www.prowessamplifiers.com/sch...elta_blues.pdf
VHT Special 6 schematic : http://www.vhtamp.com/pdf/VHT_Specia...ic_5-17-10.pdf
ian
ian
