Stupid FX Loop Question
  • Stupid FX Loop Question
    Probably sounds dumb, but I'm not sure, and I'd rather get some intelligent input than guess. I'd like to use the FX out to run thru my pedals into a DI with cab simulation for direct recording into my computer. I'd like to keep it silent. Would it do any damage to the amp if I simply left out a return to the pwr amp in?
    Short answer: turn down the master volume on the amp; rock out!
    long answer: you will do no harm to the amp with this. Plugging into the FX out without plugging into the return may not silence the amp, if it's a half-normal loop. That's why I suggest turning the master volume down. MV down may also reduce residual hum/buzz from the amp's speaker, probably not an issue when recording with a DI.
      Or wire a shorting plug and shove that into the FX return. Shorting the signal path to ground there will hurt nothing and will prevent signal from reaching the power amp.
        Just what I needed to know! Thanks for the quick reply.
          Good idea. I'll probably give that a try.
