I know 90's Fender solid state drive channels are an unpopular topic.
I know easiest solution is a different amp or using a stand alone preamp.
I have other amps but I love this amp, it was the first amp I ever owned, the only thing I don't like is the distortion on drive channel.
Theres some discussion here about the limiter circuit:Princeton Chorus Limiter circuit
but what I'd like to do is smooth out the distortion. If you could point out the key components I willing to try different values, I have a range of resistors and caps to play with. I also have some OPA2134pa op amps I can sub in too.
here is the area in question
