I need to add a switch or change one of the input jacks for using an active bass on the amp that has been fixed in this thread, http://music-electronics-forum.com/t45926/. Would a switch be the correct way or is there a way to wire one of the inputs for active and one for passive? The inputs are currently wired the way they are on a Fender amp. I suppose it would be better if one input was active and one was passive but they don’t have to be.
One way I found is to use a DPDT switch and resistors but not sure of the value of resistors that should be used, see attached image. Probably need to drop the input 15 to 20dB, just a guess.
If the switch would work, would anyone have an idea of what value resistors to start with?
