I need some experienced guys to explain what I just did.
I read on fenderguru.com about a mod to make on the Vibro Champ. I did this and happy with the results but can someone explain what I did and how this effects the amp.
I would like to know, as a learning experience, so that I know more about how these amps work.
The website says that I will bypass the tonestack. What happened is the treble knob turned into a second volume knob and the bass control works but only in a very limited fashion.
Here is the mod:
" The default 250pF treble cap should be replaced by a 0.22µF cap. Remove also the horizontally lying 100K resistor that goes from the input of the 250pF cap (now 0.22µF) to the mid and bass caps 0.1µF and 0.047µF."
This is what I did but the tone stack was not bypassed, but only modified, as far as I can tell. Or was it?
Please someone tell me what exactly was achieved with this mods by changing the cap value and removing the 100K resistor.
Much appreciated.
Here is the mod:
Much appreciated.
