JMP-1 encoder mod
  • JMP-1 encoder mod
    Ive read in other forums about fixing the data wheel issue in the JMP-1 Marshall preamp. I just got one and the patches jump around when turning the control. I guess this is common in these units . They are adding a de-bouncing chip. No one mentions "how"
    here : https://www.mouser.com/ProductDetail/863-MC14490DWG
    https://www.mouser.com/ProductDetail...CW1J-C36-CC24L
    so the encoder is 3 pins and the chip is 16 pins.
    Has anyone done this mod? Is there a scem , or can someone tell me how to do this ??
    When the encoder ages it tends to be unstable, making the adjustment difficult.
    When it is new, its precision is total.
    Sometimes I have cleaned them and they work better, but if the degradation due to use is excessive, it is enough to order a new one.
      "The circuit I used was just the standard circuit in the MC 14490 data sheet, and I attached the PCB to the back of the encoder with foam tape."
      http://www.marshallforum.com/threads.../#post-1167049
        i found some help--thanks though
          Debounce? It didn't need debouncing when the parts were new. Seems like a lot of extra effort to get around replacing a worn control.
            Apparently the datasheet for the encoder shows a recommended debounce circuit. Not sure if that means it is recommended to use one, or if it means if you are using one, here is the recommended version.
