I have a Performer 1000 (same amp as Roc Pro 1000). I really like the clean channel. I really dislike the gain channel. I cannot for the life of me figure out why they would want to design this as a high gain amp, with blackface aesthetics no less. The amp is "hybrid" in a sense that there is a tube in the gain channel, but it is only used as a clipping diode. I have tried different types of tubes (12AT7, AY7, AU7), IIRC the AY7 made the distortion a little less harsh, . I also reduced the gain in the op amp circuit that drives the tube diode. I cut the gain by about 3x, and now at least with drive at minimum you are on the edge of breakup rather than already into metal territory. The distortion is a little nasal and boxy. Looking for suggestions on other mod ideas to get more of a bluesy or classic rock sort of distortion. It looks like they change the cathode voltage for the two different drive levels, the yellow "lower gain" mode has a lower cathode DC voltage, if I were to drop that lower would I get even less clipping? I haven't found a good detailed explanation of the "tube as diode" thing. Maybe some treble bleeding would be good as well.
Thanks,
Greg
Performer 1000.pdf
Performer 1000.zip
Thanks,
Greg
Performer 1000.pdf
Performer 1000.zip
