Hi all! Long story short, I am currently using two Twin Reverbs for Rhodes. I've been using an re-201 for Reverb but I can't deal with the noise of the thing anymore. I'm thinking of getting the Fulltone Tube Tape Echo, but then I wont have that sweet re-201 reverb sound. I don't use the Twin Reverb's reverb because it just sounds way too shrill with the Rhodes, very over driven unpleasant sound. Is there something I could mod in the reverb circuit to be more receptive of the Rhodes output gain to clean up the resulting sound? Just a different tube rather than the 12at7? Or something a bit more involved? Thanks a lot for your time!
Mod Twin Reverb's Reverb Circuit for Rhodes
Exactly which model of twin reverb?
With the classic type, the V3 cathode bypass cap is simple to lift one leg of; that will noticeably reduce the reverb drive level and also make the driver much harder to overdrive.My band:- http://www.youtube.com/user/RedwingBand
Or, making use of what's probably readily available to you, plug the output from the Twin Reverb's Tank signal to another guitar amp, and disconnect it's speaker, and plug the output into the input of the Twin Reverb's Reverb tank. You'd want to do this at low level, since you have enough output capability of this extra guitar amp to do damage, and you don't want to blow the Tanks tiny transformer. Then, you can tweak the Bass, Midrange and Treble controls to see what you can get. I'd start with the Reverb control of the Twin at mid-position, and then begin tweaking the Volume/Master controls of the 'Reverb Tank amp" to arrive at a sweeter sound than you're getting with the stock Twin Reverb's character.Logic is an organized way of going wrong with confidence
Thanks Nevets! I like the extra amp idea, would be a fun experiment for sure. A different tank makes sense too.
Originally posted by nevetslab View PostWhile I've never tried this, taking the Reverb Output signal from it's 12AT7 circuit via the low impedance transformer, feeding a stand-alone equalizer, such as a 3 or 4-band parametric Equalizer...
Have you tried the new Boss RE-20 pedal? A bit pricey, but not compared to what the used RE-201's are going for!Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Driving the tank from a power amp seems kind of venturous without a dummy load and suitable voltage divider. I don't think the transducer can take more that 1..2W.
OTOH, an equalizer might not be able to deliver enough power (e.g. 0.5W).
It is easy to modify the Twin reverb circuit for less drive or less highs (do we have the appropriate schematic?). Also a different tank type may be an option.- Own Opinions Only -
Originally posted by Helmholtz View PostDriving the tank from a power amp seems kind of venturous without a dummy load and suitable voltage divider. I don't think the transducer can take more that 1..2W.
Originally posted by burymyteeth View PostI was wondering about running the amp with no load. Perhaps I could make a dummy load... That sounds like a lot of work though, i will start with the tanks!Logic is an organized way of going wrong with confidence
This article https://www.amplifiedparts.com/tech-...d-and-compared could help to find a suitable tank.
Your TR tank should be the Hammond/Accutronics type 4AB3C1B, having a nominal input impedance of 8 Ohm@1kHz (DCR = 1 Ohm) and an output impedance of 2.250 Ohm@1kHz (DCR = 215 Ohm). Any replacement should have matching values, especially regarding input impedance (meaning 8 or 10 Ohm).
It seems that keyboard players prefer shorter decay time than guitar players. The re-201 has a short reverb tank, so maybe this the direction to go.- Own Opinions Only -
