Hello everybody, I was looking for a mod that would bring my AC30C2X more into a TBX territory, I'd find out about the Caldwell mod some time ago specifically for the CC2 but apparently C2 and CC2 share some cap values so it should benefit from it too, anybody tried it on the Custom series already?
Anyway since the mapping is different between the 2 amps, would you confirm that this mapping convertion is correct?
Plate resistor mod:
R6 & R7 = R14 & R12 respectively. However, R14 is already 220k so all you have to do is change R12 from 100k to 220K
Normal channel gain increase:
R49 = R13 – jumper this for more gain. The treble bleed cap on the normal channel is C8, stock is 120pf if you wish to muck around with that. (Mod changes this cap to 100pf, and has a "brilliance" switch that puts a 68pf cap in parallel with the 100pf)
Top Boost treble cap:
C13 = C15 (stock 120pf) tweak to taste (68pf?) or remove
Tone stack tweak
C16 = C23 (stock 56pf) -> 47pf
I still have to find the C2 corresponding value of R49, C12 to complete the list
Plate resistor mod:
Tone stack tweak
