I own a 65 blackface fender pro reverb which, if you don't know, has an amazing authentic spring reverb built into the bottom of the case. I always loved the way it sounded and I had the idea a while ago that with the simple construction of this old amp I should be able to isolate it pretty easily and so be able to use it to effect something else, say a vocal recording without running it through the amp or the speakers. At first glance this seemed quite simple. The reverb is already completely isolated from the rest of the amp and is connected by two phono cables. The first thing I did was make some phono to quarter inch adaptors and run a guitar directly into the reverb and directly out of the reverb and into another amp. I then realized that an unamplified guitar could not have enough amplitude to move this heavy, foot long spring. So, I plugged the reverb back into the pro reverb and plugged the guitar into the front and went directly from the output of the reverb unit into a speaker, but I still got no signal. Could anyone tell me what I might be doing wrong? Thanks so much for your help! I have attached a schematic which is huge and annoying.
![](http://img50.imageshack.us/img50/7246/proreverbaa165schemgd4.gif)
