According to literacture I am told that if I have a Deluxe Reverb made after 1976, a blackface mod will not give you the benefits unless the transformers are changed, and that the cost isn't worth it. Mine is a 1979 Silverface with some mods already.
So, what would I be up against if I decided to change transformers and do a blackface mod. I assume power transformer as a minimum. Can you get them? Possibly output transformewr as well ?
I am sort of committed to this amp as its a grudge thing at this point. I've got it sounding fairy good by changing the 6V6 output tubes (tungsol) and setting bias to 21ma to start with. I also have changed all other small tubes plus 5U4G power tube. Ive just rekindled my electronics background and starting opening it up and making measurements. Also I have other modes already in place. I have an effects loop, master volume, and a 6 position fat switch all installed by Paul Revera. Recently I traced out the effects loop mod and made a schematic of it and then debugged it since it wasnt working. It has an extra 12AX7. There was a short between two added components and also the pull switch in the pull switch/return pot was dirty and open. Right now I am running a BigSky reverb in the loop as a Plate Reverb. I don't like the effect of the onboard spring reverb. I am assuming I should be able to get a good sound out of this amp since Paul Yandell and Chet Atkins recommended it to me. They didn't however specify a pre 1979 silverface or a blackface.
Thanks
Thanks
