Hi,
I want to connect a dummy load to the output of my Crate GTR80DSP amp so that I can safely disconnect the speaker. Power will be kept at very low levels. I thought I could connect an 8 ohm 80w WW resistor in place of the speaker. I know dc resistance is different than impedence, but they are pretty close for my purposes. I probably will go to a 10 or 12 ohm just to be safe.
The amp is a hybrid, and I do not have a schematic, but I do have a block diagram that shows a tube ( I think a 12ax7 or 12au7)) along with a mosfet in the output section.
I also thought of using another speaker and cutting the cone out and using it it in place of the amp speaker to act as a load.
What do you all think?
