I have a guy who asked if I could install some LED strip lights to his head box. Where would a GOOD place to tap 12vdc into be at?
5150 LED strip lights
There's no 12vDC but you could use the 23V supply, divide the LED strips and run them in series. Some of these strips can draw a fair amount of current - so think about the loading.
https://www.waveformlighting.com/pcb...n-a-24v-system
https://www.mouser.com/ProductDetail...xKtWirsA%3D%3D
this would probably fit ok with some double stick or velcro
The LEDs likely need very low current, so a very small transformer could power them. I agree to rectify the AC and filter it, but that takes little room as well. Mount the little transformer inside the chassis and wire its primary to the mains circuit of the amp. Then it comes on and off with the power switch, and doesn't take up another spot on your power strip.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThe LEDs likely need very low current, so a very small transformer could power them. I agree to rectify the AC and filter it, but that takes little room as well. Mount the little transformer inside the chassis and wire its primary to the mains circuit of the amp. Then it comes on and off with the power switch, and doesn't take up another spot on your power strip.
If you don't know where your going any road'll take you there : George Harrison
Originally posted by shortcircuit View PostJust an example (new thread coming on this) . This circuit board is out of an 8ft led lamp, there are 2 of them each running a 4ft 120 led strip . Just posting for size compatibility to give you an idea hope it helps.
[ATTACH=CONFIG]57095[/ATTACH]
Yes, a crude SMPS. No common-mode filtering, no EMI filtering. The PWM is dirty and noisy, especially when run 'light' with a load a lot less than it was designed for. A lot of the cheap ones come with unverified standards/compliance numbers and do not meet minimum noise requirements. Besides radiated noise, both from the unit and from connection leads to the LED, they can put noise back onto the mains.
Not so bad at a distance, but as an experiment hold your guitar near to one of these, especially with some gain on the amp. Now think how that may sound built into the amp. They may not all be bad, but you'd have to pick the right one or be lucky.
