My depth pot range is short to say? DoesnÂ’t really change anything till about seven on the dial, ItÂ’s a 5g9 tremolux. I am using a 3rma pot with a 160 ohm res to ground. I have -19 volts on each side of the wipers. Measured middle lug at full depth (12) measures -29 volts. I would have to double check this measurements.
Trem works great with the speed at 2/3 and the depth 10-12 range. Should it have more range (or do something a little more noticeable) before 10? Ok, 7-10 has a little effect going on.
I have tried a couple different 12ax7Â’s
Thanks for the insight
