Hi, again...
I,m going mad with Ohms Law!!
I want to add a Rk/Ck selector to my ampŽs tweed channel, 2nd stage (Pin8)
Using a 3 position, center off switch, i,m looking for this values:
2.7k - .68uf
1.5k
1.5k - 25uf
No problem with the caps. Problem are the resistors...
I calculated a lot of paralell combinations and always fail.. The problen is the center position.... If ground a 2.7k resistor in pin8 and paralell it with a 3.4k in the 25uf position = 1.5k... no problem.
In the the .68uf position no paralell resistor is needed..
My headake is the center position.... the 1.5k position without cap....no way!!
Here are a layout of the switch. (3 position, 3 circuit)
(1) (2) (3)
(4) (5) (6)
(7) (8) (9)
thanks!
2.7k - .68uf
1.5k
1.5k - 25uf
(1) (2) (3)
(4) (5) (6)
(7) (8) (9)
thanks!
