I'm sure someone has thought of this already. In this case I have a Hiwatt 50 with the MASSIVE power transformer which I think might handle two more output tubes and an extra driver tube. If the B+ voltage were to drop that would be OK with me as long as the heaters stay up. I could switch to 6V6 or 6L6 tubes if I HAVE to. If this power transformer was the same as the 100 Watt model it would be a go right? I think I've added about 700uF of first stage filtering prior.
Question: IF both output tubes get their B+ from the same point (center taps) would there be a lot if interaction between L and R channels? Or do the wings of the OT primary windings keep them seperate enough? Anything else to consider?
I am so happy today as I bought a 1982a Marshall cab with the vintage grill cloth used. Earlier bought a Lexicon MX400 reverb/delay unit as well.
I'm really hyped. So I've got a beautiful array of gear (OK also a midi patchbay for pedals) so if I can sync it all up....look out!
