I like my DRRI. Great tone, but in order to get it to break up nicely, it has to be turned up a bit (which equals "pretty loud"), and it's a little harsh at "friendlier" stage volumes, especially when using a pedal trying to get some overdrive. I'd like to get a little more gain from it at lower levels, without using a pedal, and try to get closer to that "British" sound.
I'm going to try a few of the known preliminary things like clipping the Vib channel high-pass cap (I may install a switch to engage\disengage it), as well as changing\rearranging the tubes and speaker.
From what I've read, I understand that removing the Normal channel pre tube altogether, and changing the Power Tube Driver to a 12AX7 will each add some gain\drive, which may do the trick. However, I was wondering if it's possible to swap out the stock 6V6 power tubes for EL34s, and if it was a lot of work to do so. Can anybody offer some advice?
