My Traynor YCV20WR had a very tinny reverb (Accutronics tank) with feedback. This problem is widely reported, and most players say they never turn the reverb up past 3 or4, pretty much writing off the reverb.
At the advice of some of the guys here, I got the schematics from Traynor's site and raised the value of a 100pF cap C35 in the recovery to 560pF and lowered the value of a shunt 200pF cap C59 to 100pF (used the old C35). I also swapped send and return leads to the tank itself, which eliminated feedback.
Now the reverb is not tinny, perhaps a bit chunky; and I can use the reverb in its entire range for the first time.
Here's the old thread:
Spring Reverb Options
I noticed now that amp hum increases gradually as I turn the reverb up, until at full tilt it's pretty loud. Since I could never do that before, I'm not sure whether it pre-existed. Is this normal for a spring reverb? Could it be that I shouldn't have re-used that old cap that I might have heated up too much getting it loose?
I'm also wondering about replacing some resistors in that circuit that Traynor replaced in later versions of this amp (past v 3.0). Those changes are recorded in the Traynor schematics on page 6 I think. Would these resistor values have anything to do with the hum?
