capacitors for a pc30
  • capacitors for a pc30
    Hi all, I just joined this forum, and i have a few questions..
    I just purchased a pc30 and am looking forward to modding it.
    The problem is that i don't found style capacitors that Steve Ahola recommend in blueguitar.org..
    for example.
    bass and mid cap (c18,c19) :steve recommend orange drop 418p.. where i can buy them?? or i can use another type as 715p or 716p??
    For cathode bias switch:
    22uf electrolitic and 0.68 uf poly?? what brand ? what's the diference /25v or /600v, i can use 715p??
    Sorry for my english...
    thanks
    Orange drop is just a brand, any film cap with similar rating will work fine. Some people prefer certain brands, but all brands work.
    22uf cathode cap - of you refer to a cap on the cathode of a 12AX7 then 25v is fine. it is an electrolytic cap.
    0.68uf cap - same situation, if it is used at the cathode of a 12AX7 then a low voltage cap is OK. High voltage caps like 400v and 600v are used when the cap connects to the plate of a tube.
    You speak English better than I speak your language.
      ok, thanks Enzo..
      but i can't found 0.68 or 1uf uf poly cap with 25v?? for cathode bypass.. any suggestion??
      I'm looking in www.tubesandmore.com..., etc.. do you know where i can found all capacitors??
      thanks
        You can always use higher voltage caps. If you don't find 25v ones, the 400 volt ones will work fine
