OK, this might be totally ridiculous, but has anyone ever tried running the reverb send on an AC15cc into a pedal delay, and then back into the amp using the reverb return?
Using the reverb in/out on an AC15cc for effects loop?
Is that a transformer driven reverb? If so, I would just terminate the transformer into an 8Ohm / 10Watt resistor then add a 5-10k pot as a send level to keep from overdriving you effect input.
The send to a reverb typically has a high pass on it so that the reverb doesn't end up sounding all muddy. You might want to increase the value of the cap leading into the reverb send tube if you want full range reproduction through the effect.
