I recently changed some caps in my DRRI.Vibrato/reverb channel.Coupling caps first,then the tone stack caps.All of this was done to make the amp a little warmer sounding.The first time around I used all Orange Drops.Then I bought some Mallory's and replaced the OD's with the same values.All except for one.A phase inverter coupling cap,C25 on the schematic.That was a .001uf to be replaced with a .0022uf.I didn't have one the first time around so I left it stock.I also did not change the bass and mid caps at first because of the size of the OD's.
After the Mallory's I expected to get an even warmer tone because of the construction differences between the OD's and the Mallory's.The normal channel became a lot closer to what I am looking for,and I am attributing that to the phase inverter cap change.I changed nothing else on that side.
The vibrato channel became brighter,a lot brighter.I did not change the values,only the brands.So I went back to the stock tone stack caps and the that side warmed up again.
I guess my assumptions were wrong.I plan on putting the Mallory's back in the vibrato side and try some tweaking to remove some high-end.From what I have read the Mallory's should make the amp smoother sounding.
Here's the question.Where would be the best place to tweak that side to get rid of some treble?My first thought would be the treble cap,But,it is the same value as the normal side treble cap.The vibrato side high pass cap(C10) was removed before I started any of this.So maybe in the vibato or reverb circuit? C13 is a high pass cap.I removed it.R32 and R33 is a voltage divider.Maybe a small cap across R33 to ground?C12 is a coupling cap that I left at stock value.Maybe replace that with a .047 or larger?
Any thoughts would be appreciated.Aubrey
