Hi, First time post, been a little while looking, i hope someone can give me a few pointers in the right direction.
I have a ashton viper 100 all tube amp, i know it isn't anything fancy, but it is all i can afford right now, so i am looking to change it a little, when i bought it it was fitted with 6l6's and 4 off 12ax7's,i have since changed it back to the standard el34's and at the moment i am fiddling with preamp valves to try and clean up the clean channel, being fairly new to this type of circuit i am realising that the clean and overdrive channels are using the same preamp valves even though they are on seperate channels. so how can i go about cleaning up the clean channel. will i have to change resistors and caps along the circuit around V2 and V3??????
Any suggestions would be greatly appreciated.
cheers
Geoff
cheers
Geoff
