I have built a single ended EL84 based 6 watter that is very similar to a Matchless Spitfire in all of the major component areas. It sounds great cranked, but it sounds particularly thin at low volumes.
I haven't messed with bright cap substitutions much, and I am wondering if the 180pf bright cap's affect is diminished enough when the amp is cranked that it has no real affect at that point. I really only play this amp either cranked at gigs or at bedroom levels (either on 3 or on 10), so if the bright cap is doing nothing when cranked, I should be able to remove it (or find a value better suited to songle coils) that makes it sound "rounder" at low volume without affecting the cranked tone which it currently possesses - right??
Thanks,
Greg
Thanks,
Greg
