59slp cap mod
  • 59slp cap mod
    I have read that sniping caps c17 anc c18 will kill some shrill in theses amps. My question, when they say snip do they mean that, or bypassing them out with wire. Thanks Louis
    Snip means cut - as in cut the wire and remove the cap.
    Putting a wire in place of a cap would be shorting across the cap.
      Sorry, I meant after removing the cap, reconnect the two points by wire.
        don't replace the snipped-out cap with anything.
          Right, replacing the cap with a wire is the same thing as shorting across the cap. Once there is a wire there, the electons wouldn't know whether there was a cap or not.
