I put a Torres post PI MV in my Fender Bandmaster 11 years ago. I have wrestled with this amp for 11 years trying to tweak it into sounding good, but always had an annoying problem with excessive shrill high end, no matter what I tried. It always "almost" sounded great, but continually frustrated me when I tried to tweak it into "that sound".
Tonight, I decided to get drastic (for me, anyway). I first disconnected the NFB. Noticed "some" difference, but nothing earth-shattering (keep in mind I have a sleeping wife on the second floor, so I couldnt crank things up too much, even though I'm in the basement).
Next thing I did was to "standardize" the PPIMV, since the Torres version is "backwards" (the wipers are "fed" from the first set of caps, instead of the wipers "feeding" the 2nd set - did I explain that right?).
Anyway, now the amp is a whole different critter. The shrill highs vanished, as if by magic. The excessive rumbly farty bass has been tamed. It doesn't have the same amount of grind that it did before, but it just sounds "better".
I feel like I have something to tweak and work with now to finally get this amp where I want it!
I'm not real sure why reversing (or "standardizing") the post PI MV connections made such a big difference, tone-wise. I don't think disconnecting the NFB wire was the big factor as much as changing the PPIMV connections was.
Can somebody explain to me just what I really accomplished here?
Thanks,
Fred G.
Thanks,
Fred G.
