Hello all,
I'm new here and I was wondering if I could score some guidance on my situation? I've replaced R1 and R2 on the preamp board to 220K/1M resistors and changed R27 to 82K.... Prior to that I swapped out the brite cap to a 56K resistor but it worked after that mod.
After the latest two I'm not getting any power to the amp I have yet to see if I blew a fuse or 4 but just from a quick check there are two on the board which are not blown and another two (including the one on the back of the amp) which covered in white so I can't see if they're blown. I may just replace those tubes first and then go through my soldering work and make sure it's all good still. I'm almost positive that the ribbons are the right direction from when I pulled them off....
Any suggestions?!?
Thanks,
Gary
PS when I just tried to discharge the capacitors there was no spark nothing... Am I safe to assume that it's a fuse that's blown?
Thanks again.
Any suggestions?!?
Thanks,
Gary
Thanks again.
