Hi everyone,
I have a question relating to the effects loop of my Marshall TSL100. It has two loops, one each for the clean and dirty but if you are only using one loop at the time it is recommended to use the clean channel loop.
The drama I have noticed is that the volume is lower when using the loop on the crunch and lead channels (It's ok on the clean).
When I turn the (crunch / lead) loop wet/dry mix knob up the volume is definitely lower than when the loop is switched off.
Is there a way to overcome this by modifying the circuit of the effects loop for the crunch / lead channel to be louder?
Thanks,
Thanks,
