Originally posted by Blindog
View Post
Fender Bassman 10 project
The Bassman 10 amps I've seen had very cheesy, tiny little output transformers. The speakers were usually 32 Ohms, wired in parallel for an 8 Ohm load to the transformer. For a fatter tone you could install the Fender "Universal" 50W OT with 2, 4 & 8 Ohm taps, the pilot holes for the larger transformer are probably already on the chassis. Then you would have a better OT and the ability to a set of 8 Ohm Super Reverb speakers (or others) if you desired. Or you could go for an "even better" replacement O.T., perhaps Mercury Mag, or ???
RE
Originally posted by Rick Erickson View PostThe Bassman 10 amps I've seen had very cheesy, tiny little output transformers.
RE
Mark
