What resistor would i use if i wanted to omit the second input jack on my ab763 clone? there is usually two 68k ohm resistors (grid stoppers). some builds i have seen online pictures used one input jack with two 68k ohm resistor. One 68K res would be ok? one input, 33k res? Thanks for the help
One input jack for ab763 clone
Originally posted by Dandrix View Postone input, 33k res?Last edited by Leo_Gnardo; 07-28-2020, 07:23 PM.This isn't the future I signed up for.
The hi gain input (No. 1) uses the two 68k resistors in parallel, resulting in a 34k grid stopper. Together with the input capacitance of the 12AX7 of around 150pF this constitutes a low pass filter with a corner frequency of around 30kHz. Using only one 68k grid stopper would lower the LP corner frequency to around 15kHz. Shouldn't make an audible difference.- Own Opinions Only -
