Hello all,
I have a dr103 HiWatt that needs the bias voltage increased to get the idling current of the EL34s down from 50ma to a more reasonable 35ma.
The max the diode & filter can manage even with the divider resistor to ground disconnected (which you'd never want to do) is about -46vdc which yields about 40ma per EL34. Seems a bit high to me & would like more range to play with.
The AC from the winding is about 38vdc max. I've seen a voltage doubler ckt for this type of situation somewhere...anyone seen that one?
I have in the past added a filter directly from the diode output to ground & this tends to increase the resultant output, but in this case not enough.
Thanx, glen Mars Amp Repair
