I have an old Oahu (by Valco) amp from the '50s that's still using 10" field coil speaker (schematic here: https://elektrotanya.com/gretsch_g61.../download.html) .
Everything's working fine after a cap job.
I love its tone and I absolutely do not want to get rid of the old Rola field coil speaker. It's a great recording amp as is (2×6V6, octal preamp tubes, field coil speaker).
Anyway, I'd like to gig with it in small venues without the risk of blowing the rare (and nice voiced) stock speaker.
My idea is to install a switched jack connected to original OT secondary to allow an external speaker, having:
- permanent shared negative connection (external and field coil speaker);
- hot wire connected to the old Rola when no input jack is inserted, otherwise connected to modern PM ext. speaker.
By doing that I could keep the field coil circuit in place and fully working (no need to deal with field coil replacement/emulation).
At the same time I could easily use an external 8 ohms cabinet.
Weight is not an issue with that old little combo amp. No problem in carrying the unused stock speaker when gigging.
I successfully installed a similar jack on a Float-A-Tone amp who already had been equipped with an ext. speaker input. I wanted speaker selection to be strictly alternative and the switched jack worked out fine.
Now the stock field coil speaker makes it all a bit more complex (maybe not!).
I have a very basic knowledge of how field coil speakers actually work. I'm assuming that the field coil speaker can actually live with no signal from OT secondary whenever external PM speaker is connected. In any case the amp would keep on seeing a field coil as expected. The OT would always be connected to a 8 ohms speaker. It looks like a win-win.
Is it a crazy idea? Am I missing something?
Of course, I don't want to damage any component. The purpose is to keep the amp stock with some added flexibility (and reliability) for gigging usage.
Am I fooling myself?
Any opinion would be appreciated.
Thanks!
