Has anyone around here modded one of these guys? I picked up a head and cab a few weeks ago and I like it but it's not quite there yet.
According to a schematic I found online (not from Fender), the amp has an input gain stage, gain control, 2 more gain stages, a TMB tone stack that is very similar to a 5F6-A Bassman except driven from a gain stage instead of a cathode follower, master volume, and a final gain stage to drive the single EL84. Preamp tubes are both 12AX7A. There is a footswitchable treble "boost" that unmutes the bypass capacitors for the first two gain stages. All cathodes have their own resistors and bypass caps.
I replaced the the stock 12" Celestion V-Type with a JBL MI-12 and that got me some high end sting that I couldn't get but now the bass response seems indistinct. The bass is there but it isn't as tight and defined as I'd like. The treble boost is now too intense, before, it was right on the edge of barely enough treble without, almost too much with. The cabinet has 2 3" x 6" oval ports, I'm going to experiment with plugging one or both of them or maybe taking the back off the cab. I may try a different speaker.
I have thought of making the boost only operate one bypass cap or maybe changing some values in the tone stack. I'll work a little more with the speaker and cabinet first.
I guess I should say that I have a Super Reverb Reissue that I love and that my main goal when buying this amp was to be able to get good breakup at non WMD levels. I actually really like it and want to tailor it to my use rather than try to turn it into a low power high gain Super Reverb.
