Hi,
I have had this little amp since 2017. Thanks to Cameron Jenkins in this forum I got a schematic. The thermistors were glued to the chassis but had come loose so I glued them to a chunk of aluminum with thermal adhesive and bolted that to the chassis. Otherwise I just cleaned up the pots, changed the PS capacitor from 2200uF to 3300uF and replaced the power supply diodes with UF4007s. That helped out with bass and I have just been goofing around with the amp since then.
Now I would like to make a few changes to the amp just for fun. I was thinking about building a Tillman preamp into the amp instead of using a boost pedal, but was wondering about tinkering with the MIC preamp already in the amp instead. Any advice on how to go about that or should I just leave it all alone and find something else to do?
The other thing I was wondering about is why is there is a 2M2 resistor between HOT and the chassis? The chassis is also connected to the power ground.
Thanks, Jeff
Thanks, Jeff
