I have 2 1980's solid state Marlboro Sound Works 1200R amplifiers. I got one a couple years ago, and wanting to try a bit of a stereo rig, I got another identical amp this past week. The one I just got is quite a bit louder on the same settings as the older one. I opened the new one up and discovered a large capacitor had been added to the underside of the circuit board.....as you see in the photos. I'm wondering if this cap is what accounts for the beefier volume. I can see no other modifications other than the added 1000uf35v capacitor. I thought maybe the 1st amp I got was just tired and weak....but I think the "new" amp has been hot-rodded a little. Anybody have any ideas what that capacitor is up to in there? I circled in red where the cap is connected, to the board and to the chassis. Can see no other differences between the two amps. Not sure if I want to remove the cap and have the amp sound closer to the other....or add a similar cap to the older amp and beef it up too. I kinda like the older "weaker" sounding one better maybe. Does anybody know if I can snip that big cap outta there, just by looking at the pix? I want both amps to be the same for the stereo rig. (though two different amps can sound good also). The one amp is not only quite a bit louder but has a slightly different tonal quality. Thanks for any help on this. Here are the pix:
(the reason I know the cap was added to the one and not taken out of the other is because the cardboard circuit board covering cannot possibly fit on, at all, with that big ol' capacitor there.)
