Hi all, Thanks in advance to everyone who posts hear Ive always gained alot of knowledge reading here. Now to the question. I am going to add an external speaker jack to my champ 12 ..Ive read somewhere that you can simply add a 1/4" mono jack with a switch to the wires going to the internal speaker which then go on to the internal speaker after being soldered to the jack. My only confusion is getting the right kind of jack. Ive seen mono jacks with a tip shunt and mono jacks with a switch. It should have three lugs tip, ground, and switch. This is all done so when I plug an extension cab into the jack it will drive the cab and not the internal speaker. Thanks Val
