I remember another thread here about a MB amp with a short lead off one of the preamp filament legs. It was speculated at the time that it was probably there to mitigate hum by introducing inverse phase. I have some designs that place the input preamp tube very close to the input jack to avoid a long, shielded lead for that circuit. Then a little 4.7pf cap from grid to plate. But even the 4.7pf cap is probably more than I need (and just barely audible) so I've considered just a twist or two between the grid and plate leads there. This idea actually comes from Marshall. I noticed that in their JMP amps the input triode grid and plate leads were often placed parallel for a short run and then tacked to the chassis with a blob of goo. Later Marshalls did use an actual capacitor between the grid and plate on the input triode. Then, still later, Bruce Zinky did on some Fender designs. Marshall and Bruce having not come up with Peavey's clever solution for achieving this without an actual capacitor on PCB's where leads can't be placed side by side or twisted intentionally.
Capacitor between screen and control grids
- Likes 1
Originally posted by Chuck H View PostThen a little 4.7pf cap from grid to plate.
I guess you prefer a low capacitance guitar cable to compensate ?
That will increase the amp's input capacitance from typically 150p to around 400p (Miller effect), lowering PU resonance.
The addition of 250pf input capacitance is really only like an additional 8' of cable. No big deal in my opinion. And like I mentioned, I'm considering lowering that capacitance and even eliminating that capacitor in favor of just a couple of pf by a twist in the leads. Not so much for personal tonal reasons but because most players prefer a the brighter tone and removing the cap means there's no component that could short and put HV on the input jack. I know there are capacitor types designed with an OPEN failure mode. And I use those. But I still think about it."Take two placebos, works twice as well." Enzo
Originally posted by Leo_Gnardo View Post
Been there! And we've all seen it in movies. Good description - zig zag pattern."Take two placebos, works twice as well." Enzo
