Since I was not satisfied with trying out different preamp tube, I am thinking to lower the gain on channel three by maybe removing cathode bypass cap or by increasing value of a cathode resistor. Am I thinking in the right direction? And should I do that at V1-A (C17 and R42) or at V2-A (C16 and R45) location... or any other thoughts and suggestions on values and ways to do it, please? Talking about my EVH 5150 III 6L6 MkII 50W amp.
Lowering gain by adjusting cathode resistor value or removing cath. bypass cap
Increasing the cathode resistors will lower gain, but also headroom. There are limits on how much gain you can remove and still sound good. Removing the caps will lower gain, but not as much in the low end. Can't you turn the Three Gain control down far enough ? Inserting a resistor between WJ10 and WJ3 might help, try 1 Meg.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
- Likes 1
Perhaps change plate resistor R72 to a 100k value. In a few instances I have removed cathode bypass caps on amps that I designed. Those designs were all about cascading gain with a preamp full of too much gain. Removing the cathode bypass caps helped remove a tiny bit of gain. It was enough to tame it down a bit but it was also about the tone too. Since the bypass cap was part of the equalization of that stage of the circuit. In my case it worked okay but it is finite adjustments at that stage of tweeking the circuit.When the going gets weird... The weird turn pro!
Originally posted by loudthud View PostCan't you turn the Three Gain control down far enough ?
Originally posted by Mick Bailey View Post
That's an important point. Because the control goes to zero, is there a point where the gain reduces to where you'd want it (even if it's only just fractionally off zero)? This would give a better insight into where the gain reduction is best placed - whether the signal needs to be attenuated just before the gain control but after the preceding stage, or whether the gain of that stage needs reducing. Or maybe some of each.
Originally posted by Emetal View PostIf I turn Three Gain too low like below 2, I start loosing power, or should I say volume all together. It sounds tiny and sterile.
- Likes 1
I haven't gone back to the old thread to see if this suggestion has already been given or been done, but...
If the Z1/Z2 circuit is clipping at whatever gain setting you use then it seems to me that if you lift either lead of either Z1 or Z2 you would be able to reduce clipping and actually gain a little volume. Allowing you to keep the gain knob in a better spot for balance with CH 1&2 perhaps. This would probably change the character of the channel quite a bit. but maybe for the better.
EDIT: Don't bother with this. See post 10Last edited by Chuck H; 12-25-2022, 07:56 PM."Take two placebos, works twice as well." Enzo
Originally posted by Helmholtz View PostZ1/Z2 might be necessary to limit the drain-source voltage of Q1."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostMust be the case. I had suspected by the Zener value and their location that they might not be signal clipping diodes so I simulated the circuit. The most you'll get out of that first triode is going to be about +/- 10V on big chord attacks. So at 16ZV they'll never clip the signal even with the gain pot up full.
1Vp PU signal at attack is possible.
V2a grid conduction will limit positive signal but not negative signal.Last edited by Helmholtz; 12-25-2022, 08:34 PM.- Own Opinions Only -
Originally posted by Helmholtz View Post1Vp PU signal at attack is possible."Take two placebos, works twice as well." Enzo
Originally posted by Helmholtz View PostZollner measured PU instantaneous peak voltages up to and above +/-1.5V using a LP with Burstbuckers strumming chords.
As these are fast transients measuring requires a scope.
Even at a volt of input it doesn't seem to matter in the simulation because grid conduction from the following stage smashes one end of the wave form before the diode can have any affect and the other end of the wave form is clipped in that stage well before the diode clips what is going in. There is no difference in the clipped wave form or equalization from the second preamp stage with the diodes in or out.
- Likes 1
