I have a pair of old GE 6L6 tubes that I dropped in the amp, but my infrared temp meter shows a huge difference between each, making me think they're really not balanced. To make sure my meter doesn't read the glowing heaters I shut the amp off and measure after a few seconds.
The Hot Rod Deluxe has a 1 ohm cathode resistor to ground, and the bias checkpoint measures both sides. I'm thinking of simply separating the path to ground of each 6L6 and putting another 1 ohm resistor.
I'm just worried about the diode in parallell with the 1 ohm cathode resistor. That diode is called CR3 on earlyer versions, and D3 on version III. On my amp it's a 1N4006. Should I put a 1N4006 diode in parallell with both 1 ohm resistors? (each sides)
Next idea would be to add a bias balance pot like Silverface Fenders.
