Do you know where I can get the power and standby switches that would fit that Solarus amp ? What about that rate pot if needed also ?All of my rockers are too wide and I've tried ordering some but can't seem to find the right size.
Question Soundmaterg ?
That's a good question tmenzo and you'd think I'd have that info but I'll post it back tomorrow after I get to the shop and take some measurements but yes they are quite odd and taller than the normal rockers in todays amps.KB
This is courtesy of Conrad...
Greg
OK try this web address: http://www.carlingtech.com/pdf/s_ltil.pdf
The switch was made by Carling Technologies. This appears to be the same switch with screw mount and neon lamp on the side. Doubt if the switch is available unless in distribution channels – they might know who would have the switch. Fender might have a stock on hand.
Hope this helps.
