Can anyone help with a copy of the operating guide for this amp?
Sunn beta lead user manual?
There really isn't a user manual online anywhere. Basically there are two channels. When you plug into either channel, an LED will come on. If you plug into the "Both" input, both LEDs should come on. If you have the optional footswitch, you can select either channel or both at the same time when using the Both input. Each channel has an Effects loop and there is a Master Effects loop that is just before the power amp after the two signals are mixed together. The output is 100W at 4 ohms.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
