sunn concert lead reverb
  • sunn concert lead reverb
    Looking for a substitute reverb can for 72 concert lead...no markings on original...thanks
    We need the can length / width, number of springs
    you know that it is transistor drive transistor return
    and that Fender bought what was left of Sunn...
    what you have, is that Fender may have a record or a parts list
    or that there may be a service manual with a part number.
    Used to be that manufacturer like Accutronics kept records of what tank for what amp...
    and if that were to fail, you can still look at similar reverb systems in other amps.
    the reverb part number contains the info above such as number of springs...
    and how to come up with a part number:
    reverb_tank.pdf
      Check out this link Concert Lead Reverb Tank
      The Concert Lead used a folded line compact tank with the famous label that says:"built by beautiful girls under controlled atmosphere conditions" or some such
