When my Sunn Sentura II is sitting idle with the volume turned all the way down, there is a certain amount of hiss in the speakers. When playing loud, it's not a problem. When recording in a studio, it would be nice to have it quieter. The amp has been completely recapped. The tubes are in good shape. Everything is working as it should - except for the noise. Some people say the problem is resistors. I'm wondering where you think I should look. The hiss level does not change with the volume control, so the problem is not in the preamp section.
Sentura II Quiescent Noise
Originally posted by patlaw View PostWhen my Sunn Sentura II is sitting idle with the volume turned all the way down, there is a certain amount of hiss in the speakers. When playing loud, it's not a problem. When recording in a studio, it would be nice to have it quieter. The amp has been completely recapped. The tubes are in good shape. Everything is working as it should - except for the noise. Some people say the problem is resistors. I'm wondering where you think I should look. The hiss level does not change with the volume control, so the problem is not in the preamp section.
http://www.geofex.com/ampdbug/hiss.htm
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Does turning the Treble Bass and Contour controls to zero affect the level of hiss? How about turning the Reverb control down?WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by loudthud View PostDoes turning the Treble Bass and Contour controls to zero affect the level of hiss? How about turning the Reverb control down?
Let me say that this hiss is not a major problem. Since I play the amp at home at low volume and do some recording with it, I'd like to reduce it as much as possible. That's why I wonder if the source is as esoteric as the plate resistors, which are easy enough to replace. I'd still like to know which components comprise the B+ decoupling string.
The PS resistors adressed in the link would be the ones between points A,B,C,D in the schematic. These resistors may produce some noise, but if the filter caps are good, most any noise is shorted to ground.
If they are carbon compound types, replacing them with wirewounds might help a little. I wouldn't expect a significant difference.
But things are different with bad/aged filter caps.- Own Opinions Only -
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Helmholtz View PostThe PS resistors addressed in the link would be the ones between points A,B,C,D in the schematic. These resistors may produce some noise, but if the filter caps are good, most any noise is shorted to ground.
I would be suspicious of those two high value (220K and 620K) resistors at the input (pin 8) of the 6AN8. Replace with metal film if you can find them.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Some early Sunn schematics contain errors. Since many Sunn amps are nearly identical, compare it to a similar amp as @g1 did in post #9 above.,WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
- Likes 1
