Hey y'all
I've included a schematic at the bottom
Got a Sunn SL 260 2*12 combo that will not output more that half a volt on the negative supply for the pre amp. I'm at my wit's end here. Every transistor tests fine, the output transistors are brand new and are stable. The negative voltage to the power amp and various transistors is fine. I'm not super clear on which components regulate the voltage for the preamp, but everything looks kosher up until pin 4 on the first opamp in the power supply which reads .5 volts no matter what ac voltage it sees from my variac. Any advice would be sick. Thanks!SL 160-260 Schematics.pdf
