That's pretty much what I was thinking except I hadn't considered going full wave. I like the 100k "safety" resistor addition. Valvewizard is a good source. And FWIW I looked into it a little and I see that many ab1 KT120 circuits are using 100k bias feed resistors. You could go lower than that for insurance of course and the max 14.7k bias node resistance makes it easier to use a relatively low value for the bias feeds I did a quick CAD sim and it looks like steady bias voltage will take about 1 second. Better than many bias supplies.
Bias supply and Rg1
Originally posted by catalin gramada View Post
Yes, bias till max 70% power dissipation and it may double it. Some datasheets published the ratings for different power dissipation.
I don't know where the 70% comes from in your example data sheet. They show for above or below their maximum rating of tube (27W Wa+g2 of tube rated for 25W Wa).Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
That's a typo , should read 17w instead 27w that seems impossible for a 25w tube, of course.
Last edited by catalin gramada; Yesterday, 06:40 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Anode plus Screeen dissipation is above or below 35 Watts. Max Anode + Screen Dissipation is 42 + 8 = 50 Watts, so 35/50 = 70%
Originally posted by Chuck H View PostThat's pretty much what I was thinking except I hadn't considered going full wave. I like the 100k "safety" resistor addition. Valvewizard is a good source. And FWIW I looked into it a little and I see that many ab1 KT120 circuits are using 100k bias feed resistors. You could go lower than that for insurance of course and the max 14.7k bias node resistance makes it easier to use a relatively low value for the bias feeds I did a quick CAD sim and it looks like steady bias voltage will take about 1 second. Better than many bias supplies.
