Hello Everyone,
I'm in need some good technical guidance on the re-tubing of a standalone Mesa preamp. Specifically, I need some feedback on the various types and designs of 12AX7 tubes out there, and their suggested or recommended application in a standalone Mesa Boogie preamp.
Basically, I've got a 1990 Mesa Boogie Studio Preamp that according to the schematic, calls for a total of four (4X) low-noise 12AX7/7025 tubes in the following locations and functions (excluding a lone 12AT7 reverb driver at V5):
FACTORY LOCATIONS/FUNCTIONS OF 12AX7 TUBES
V1A: Input and Tone
V1B: Input and Tone
V2A: Rhythm or Lead
V2B: Reverb Mix/EQ Send
V3A: Lead/Overdrive
V3B: Lead/Overdrive
V4A: Main Outs
V4B: Main Outs
So, my question is this, given all of the various renditions of 12AX7 tubes out there (i.e., NOS vs. new production, short plate vs. long plate, high gain vs. low gain, etc., etc.), what key points do I need to consider here?
For example, I've got all of the following 12AX7 tubes sitting right here in front of me new in the box, and I prefer a clean (no-distortion/no overdrive) sound almost exclusively, but which ones would you use in this particular preamp? Where would you place them? And above all, why?
1. JJ ECC83S (cost-effective, said to be of 'standard' gain)
2. Sovtek 12AX7LPS (said to produce a softer, mellower tone)
3. Tung-Sol ECC803S Gold Pin (said to be less gain but lower noise)
4. Sylvania 12AX7 Long Plates (said to draw more current with nice low end)
5. JAN/GE 12AX7 Long Plates (expected to be same as the above Sylvania's)
Do I keep the gain high at V3/V4 and low at V1/V2? Do I focus the benefits of the long plates on tone, etc. (at V1/V2)? I'm lost! Anybody?
To all who respond, thank you! You've helped make "one small step for man, one giant leap for mankind!"
V1A: Input and Tone
V1B: Input and Tone
V2A: Rhythm or Lead
V3A: Lead/Overdrive
V3B: Lead/Overdrive
V4A: Main Outs
V4B: Main Outs
![Wink](https://music-electronics-forum.com/core/images/smilies/wink.png)
